Am having major problems trying to fire up my newly built system and thought it might be best to tackle each of my issues seprately so this is the first question I need to ask
With the Nvidia 580 gtx or probably any of the Nvidia GFX cards
It has 2 plug in sockets an 8 pin and a 6 pin PEGI molex sockets
Visiting 2 different forums a cam back with contrasting answers
In 1 forum it was suggested I can use either cable
Whilst in the other (NVidia) forum people were adement that you should use both cables
The problem is that when at first I plugged in both the cables the machine would not even boot up
However when I just connected the 6 pin cable the machine starts up and I see the fans on the card spinning, but the monitor does not come on
So which is the right method either one or both together?
plz I really need some help with this
thx
thx
