Slow ram?
Do not follow, its 6GHZ on 680 or 7GHZ on 770 which is not slow.
My issue is the GPU cannot use all 4GB as it does not have the power.
Are you sure you do not mean the Memory Bus Width?
could always sli it couldn't I? Makes it the same price as the 780 ti. Remember when I brought the 580 it was better to but two 570 than one 580 and cheaper. Showing my age
