- 29 Jan 2007
- Behind You!!!
posted this in the software forum, but thought this one would probably be the better one to, so posted it here as well;
Everything worked fine up until the other day. It dected my main monitor and also my 2nd one which is a samsung HDTV. I go to set the tv to my main display today and the thing is not in the options. I force decect and nothing, reset and nothing, reinstall the display drivers and nothing. Even booted my old XP and the same thing has happened. Its nothing to do with the connections as if I reboot and connect the tv to port 1 that works fine.
Anyone know what I'm doing wrong?
