- 26 Dec 2009
- North
Hi guys, whilst I'm confident that the caps are bad I just wanted to double check and would also like to know if it possible these caps are causing the issues with the motherboard.
It's a bit strange the behaviour but I have nailed it down to the motherboard after some experimenting.
For some reason the motherboard stock setting is only setting the CPU Voltage to 1.2v when the VID and stock Volts for the CPU should be 1.25V (QX9650). Also some of the other voltages set by the motherboard automatically seem a bit low when I compare to others online using the same CPU and board.
Slight bulge
This one appears fine, nice and flat for comparison
Theres 4 caps in total that I think are bad, could these be having an affect on the DIMM slots and also making the boards stock auto volts low?
The caps read Sanyo 1500uF 6.3v (10mm x 20mm)
Ordered these - ** Do not link to competitors **
- When using 1 Module of Ram and 1.2v CPU Core (auto set by motherboard) the system appears to run fine.
- When using 4 Modules of RAM and 1.2v CPU Core (auto set by motherboard) the system will crash often and get stuck in the Windows load up.
- When using 4 Modules of RAM and manually set the CPU Core 1.25v the system seems to be much more stable with only the odd crash.
Slight bulge
