Nvidia 9800gt temps
22 Aug 2009
Was playing Crysis on High Settings and the game locked up. After a bit of digging some people put the crash down to the card overheating. Now from what i can tell using Speedfan, my 9800gt idles at 40C and when i play Crysis the hottest ive seen the card go upto is 67C. When i play TF2 i get temps of around 60C.
Are these temps dangerous / should i be worried? May i also add that im using stock fan speeds.
40c idle is about right, my 7900 used to idle around 27c & my bro's 9600gt idles around 45c.
67 might be a little high, but then again it is crysis we're talking about.
Just to add, i did a further check and found my GPU to be hitting 79Cwhilst playing Crysis (Empire total war, tf2, company of heroes, ut3 all register 55C-60C). I've since modified my fan setup and dedicated an intake to my GPU and i get 70C tops on High Level Crysis.
How hot does my 9800gt have to be before its starts dying?
