SebC said:I've been told to go to this classic control panel after enabling the Max Frames to Render Ahead option in nvTweak. However I don't see this classic option anywhere. Any ideas? I'm using Forceware 162.18. Thanks.
LoadsaMoney said:Search for this key, and change the Value to what you want :-
HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIACorporation\Glob al\NvCplApi\Policies and edit the ContextUIPolicy DWORD value.
The values are :-
1 for the old Control Panel
2 for the new Control Panel
3 to use both Control Panels
LoadsaMoney said:Isn't there a program that lets you select the old classic CP as well, something like Nv Tray.
helmutcheese said:I think some APP's did but not on all new drivers, now 100% on it to be truthfull, but its BS that some drivers cant have the CP as some peeps on forums claim.
