NVIDIA Control Panel - Best Settings
28 Jan 2011
What is the recommended settings for a 4080 Super in these settings??
there are so many "low latency mode" , "max frame rate" etc..
if somoeone could post what the best settings would be in the NVIDIA control panel that would be great!
cheers!
low latency mode = ultra is the best option for eliminating lags, it eliminates frame buffering and renders the frame just in time, wysiwyg - but a side effect is lower fps and, could be significantly lower for older cpus
max frames - as the name suggests caps fps at a drvier level, there are 2 options: one works in full screen mode and the other is for windowed mode
if it doesnt work for some older games just rename the game exe to FEAR.exe and it will work
you have also got some unique driver settings like vsync, you can set it to adaptive half refresh rate or disable it at driver level, nvidia driver level vsync is less laggy than in-game options
if you are using nvcleanstall, you can also disable hdcp at driver level and assign negative interrupt ranges, this will eliminate all sources of lag, love the nvidia control panel and drivers
genuinely just leave it alone unless you need to set a cap. some games run away in menus so setting a max FPS 1 under your screens refresh rate is always good
