Hi,
Ever since the last driver update once i have restarted my pc the nvidia shortcut in the right click menu disappears, also if i go into control panel and try to get to the nvidia control panel from there it just won't load.
It's fine right after installation just once pc has been rebooted, it's the first time i decided to co a clean install as i normally just do custom and select the driver and the phys x parts only, i even installed geforce experience today to see if that helps but it does not.
Anyone else had this problem and know a fix ? the driver seems to be installed and working, it's just annoying the control panel won't load.
