- 1 Jul 2009
- Shropshire/Paris
I have a new monitor and I am trying to get the blacks as dark as possible and reduce glow.
I have noticed that if you go into the Nvidia control panel, Adjust Desktop Colours and set it to use Nvidia settings. The hue will be 0. If I drag the slider all the way to the right so its at 359 and then back to the left to 0 again, the screen is much darker and with less glow.
What I am trying to say is that the 0 setting after you move the slider is different. Anyone else find this?
Also when I restart the PC the settings are the same as I left them, but the screen looks crap again, as if I didn't adjust the Nvidia settings. If I fiddle with the settings (move sliders) and then put them at the values I like, the screen looks good and how it was before a restarted the PC.
Any solutions to this?
Thanks
Thanks
