Huh?ajgoodfellow said:Current DX9 cards though will be DX10 compatible though
ajgoodfellow said:You can install and run DX10 games on a DX9 card
A good example would be Half-Life 2 running on a Geforce 4 Ti. Even though the GF4 is only a DX8 card, it will run a new DX9 game like Half-Life 2.
If some games require newer features that are only found on DX10 cards then they might not work and you might loose out on some special effects, but, on the whole, you will be able to run a DX10 game on a DX9 card
Noxis said:You realise that HL2 works on a GF4 Ti simply because Valve specifically programed in a DX8 code path right? If a DX10 game is released and the developers have not specifically put a DX9/8 path into the game it simply wont work.
Try latest Splinter Cell on a Rad9800 or GF5 FX... SM3.0 ONLY.
Cyber-Mav said:is that true? you sure its a sm3.0 ONLY game??
