Nvidia folder & freezing problem
28 Nov 2004
Hello all,
Everytime XP starts up the nvidia folder that contains graphic and motherboard drivers pops up.
My PC keeps freezing when playing games. First the game will freeze then the PC. After a minute or two it goes back to normal.
Anyone know how to fix these problems?
I've already got the side off.
I'll give everything a clean tomorrow and see if that helps.
Thanks for the help.
You should be able to right click desktop and select..
Properties/settings/advanced/geforce tab/then click on temp settings on left.
Oh, sorry, I know that I thought you meant CPU, RAM and GPU.
At start the GPU is around 50c, when running it tops at 59c when gaming for hours.
