Both those links to the same drivers, 32bit?![]()
Thanks
By the way, do you guys also just install newer drivers without uninstalling older ones?
Been a while since we've had a decent set of drivers! Time will tell of course
I actually prefer to uninstall the old ones first then reboot and install the newer one using the custom option and clean install unchecking the 3D and HD Audio stuff.
When I was using the 280.19 betas my card would clock up to 3D speeds in firefox sometimes(with hardware acceleration turned off), anyone know if this is fixed in these?
