Nvidia Geforce 302.59 ( BETA )
Caporegime
8 Sep 2006
On Ocuk
Supports all cards, not on nvidia homepage but they are on the nvidia developer site!
Thanks, it was only a few days since last beta, are these to fix the ''show stopping'' problem in the last beta do you know?
Hhhmm, very messy install on these, picked a clean install and it said driver not digitally signed, picked the option to continue anyway, screen went blank and never came back, had to hit the power button and restart, no driver installed at this point, restart the install and get an error, don't know what it was now either and am a little worried something is missing from them as the error said it was I think, oh well see how they go I suppose.
Worked perfectly fine here!
Just played Warlock master of the arcane without any problems too
Well I uni-stalled all Nvidia drivers through control panel, tried them again and was met with the same black screen requiring a restart so was not a one off for me, gone back to 301.40 beta as they installed fine.
Cheers Neil.
They installed with no issues and they are solid as a rock so far for watching videos and web browsing.
I will test a couple of games tomorrow after my Statistics exam.
Any reason to update to these over the most recent official release?
Had a quick look on the 3dguru forums, nothing springing to light at the moment. Personally I'm going to stick with the 301.40's.
Just found my first issue. Fraps 3.5 no longer starts with these drivers, however the clock issue I was having with the 301 series has gone my core clock no longer gets stuck at 200Mhz.
Worth noting that these drivers support a good range of cards out of the box without the need for a modded inf, I'm currently back on a GTX280 while waiting for an RMA replacement.
(as a side note for a 2008 card this actually seems fairly decent, no major weaknesses in terms of clock speed, memory bandwidth, VRAM etc so has aged quite well)
