NVIDIA geforce 7950 gx2
LoadsaMoney said:
If you play at high resolutions on 24'/30' inchers etc.. (ohh err :D ) and you want all the eye candy on then yes as the GX2 can't be touched. :)
As said by LoadsaMoney, if you play in gigantic resolutions then the GX2 is for you as it's more or less two 7900GTs in SLI.
If you only play in 1600x1200 or some such resolution though, and play the most popular games available (Battlefield 2, Oblivion, etc.) then I would suggest sticking with an X1900XT/XT-X for much less outlay as the GX2 lags in these sorts of game.
