Hey,
My PC / hardware knowledge isn't the highest so be gentle
I bought a PC about 6-7 months ago I've always had the same problem of it being really loud but I think I've managed to locate the source of the GFX card.
PC Specs :
Dual screens - both 22"
Thermotake frío CPU Cooler
NVIDIA GeForce GTX 460
Case: Zalman Z7
I've installed Speedfan and gathered some of the temperatures.
( Both games are on medium graphics )
Idle - 50C
Starcraft 2 - 65C
Call Of Duty 4 - 64C
On idle the PC is loud but once it hits around 60C it then creates a high pitched noise.
Been told by a mate that I should get a cooler, any fans / coolers that you can recommend for me? Or is this all normal for my card.
I wasn't too sure what else to add about my PC specs so just ask if you need more.
Thanks in advance.
PC Specs :
Case: Zalman Z7
Idle - 50C
Starcraft 2 - 65C
Thanks in advance.
