- 28 May 2007
Yet you're very quick to link to their reviews if the review turns out how you expected...
I just look at their apple to apples tests and guess what? they are benching the 560 1GB v 6950 2GB at 2560x1600, anyone buy a 1GB card to run at that res?? sites a joke.
Maybe, it just seems like their basing their review on the logic of 2560x1600. Although when it comes to CPU's usually they really diss AMD CPU's.RavenXXX2 said:OCP are AMD fanboys, they reckon the 6970 blows the 570 out of the water, nuff said.
The Anandtech review puts the HD6950 1GB and GTX560 1GB at level pegging. In Metro2033 the HD6950 1GB is ahead which is surprising as this is a Nvidia sponsored game.
It's obvious they bench at that res to make the Nvidia look bad, like I said if they are doing reviews to show consumers what the best card is they would bench at a realistic res for a 1GB card, and considering the apples to apples test are really the only thing worth looking at it's a big con.
If the game is playable at max settings 2560x1600 or 1920x1200 which seems to be the case in all the games benched in the [H] review whats the point in benching at a lower res as its obviously all cards involved will give a great experience at lower res.
Anyhow the gtx560 looks like another solid card from nvidia. If thinking of a purchase between a 6950 and a gtx560 you most likely have to look at the games you will be playing as to which will be the better buy.
The GTX 560 Ti ultimately has the edge: it’s a bit faster and it’s quieter than the 6950, and if that’s all you care about then there’s the answer you seek.
Yeah one card is 1GB the other 2GB, so results are skewed at max res, therefor them results have no relevance to results at a lower res, considering the only fair comparison is the apple to apples test I would not base buying a 560 on OCP's review. Go look at the other reviews where it paints a completely different picture at 1920 res where the 560 and 6950 are on par for the most part.
Anandtech, always trust them.
