***NVIDIA GEFORCE GTX 660Ti PRICE DROP!!****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As predicted, NVIDIA have moved 660Ti pricing to sit slightly below their new GTX 760 graphics, as always OcUK is first to drop price:-
Asus GeForce GTX 660TI Direct CU II 2048MB GDDR5 PCI-Express Graphics Card @ £194.99 inc VAT
The Asus GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specifications:
- Graphics Engine: NVIDIA GeForce GTX 660 Ti
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 2GB
- Engine Clock: GPU Boost Clock : 980 MHz
- GPU Base Clock : 915 MHz
- CUDA Core: 1344
- Memory Clock: 6008 MHz ( 1502 MHz GDDR5 )
- Memory Interface: 192-bit
- Resolution;: DVI Max Resolution : 2560x1600
- Interface: DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D)
- HDMI Output : Yes x 1
- Display Port : Yes x 1 (Regular DP)
- HDCP Support : Yes
- Accessories: 1 x Power cable
1 x DVI to D-Sub adaptor
- Software: ASUS GPU Tweak & Driver
- Dimensions: 10.7 " x 5.4 " x 1.7 " Inch
- 3yr Warranty
Was [£219.95] Inc. VAT
Only £194.99 inc VAT.
ORDER NOW
Asus GeForce GTX 660TI Direct CU II DC2O 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Specification:
- Engine Clock: GPU Boost Clock : 1058 MHz
- GPU Base Clock : 967 MHz
- CUDA Core: 1344
- Resolution: DVI Max Resolution : 2560x1600
- Accessories: 1 x DVI to D-Sub adaptor
1 x Power cable
- 3yr Warranty
Was [£215.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Asus GeForce GTX 660TI Direct CU II TOP 2048MB GDDR5 PCI-Express Graphics Card @ £205.99 inc VAT
Specification:
- Specially selected TOP GPU Core for maximum performance & OC potential
- Engine Clock: GPU Boost Clock : 1137MHz
- GPU Base Clock : 1059MHz
- CUDA Core: 1344
1 x Power cable
- 3yr Warranty
Was [£221.99] Inc. VAT
Only £205.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 660TI 2048MB GDDR5 PCI-Express Graphics Card @ £205.99 inc VAT
Get the weapon of choice for gamers - the EVGA GeForce GTX 660 TI. It adds a new dimension to the NVIDIA Kepler-powered family of graphics cards by delivering the ideal fusion of power, performance, and affordability. Experience faster, smoother, richer gaming with innovative NVIDIA technologies like TXAA antialiasing, Adaptive Verticial Sync, and PhysX.
Specification:-
- Core Clock: 915MHz (GK104)
- Core Boost Clock: 980MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 1344
- Shader Clock: 2012MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- TDP: 150W
- Warranty: 3 Years (upgradable to 10years with registration)
ORDER NOW
EVGA GeForce GTX 660TI SuperClocked 2048MB GDDR5 PCI-Express Graphics Card @ £207.95 inc VAT
Specification:-
- Core Clock: 980MHz (GK104)
- Core Boost Clock: 1069MHz
- Shader Clock: 1960MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- TDP: 150W
Was [£225.99] Inc. VAT
Only £207.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 660Ti FTW Signature 2 2048MB PCI-Express Graphics Card (02G-P4-3664-KR) @ £224.99 inc VAT
Introducing the weapon of choice for gamers - the EVGA GeForce GTX 660 Ti. It adds a new dimension to the NVIDIA Kepler-powered family of graphics cards by delivering the ideal fusion of power, performance, and affordability. Experience faster, smoother, richer gaming with innovative NVIDIA technologies like TXAA antialiasing, Adaptive Vertical Sync, and PhysX.
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1124MHz
- Shader Clock: 2092MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- TDP: 150W
Was [£239.99] Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 660TI 2048MB GDDR5 PCI-Express Graphics Card @ £189.95 inc VAT
The Gainward GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:
- Engine Clock: GPU Boost Clock : 980MHz
- GPU Base Clock : 915MHz
- CUDA Core: 1344
- Memory Clock: 6008MHz (3004MHz GDDR5 )
1 x Power cable
- 2yr Warranty
Was [£211.99] Inc. VAT
Only £189.95 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 660TI OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card @ £205.99 inc VAT
The Gigabyte GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:
- Engine Clock: GPU Boost Clock : 1111MHz
- GPU Base Clock : 1033MHz
- CUDA Core: 1344
1 x Power cable
- 3yr Warranty
ORDER NOW
Inno3D GeForce GTX 660TI Herculez 2000S 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
The unveiling of the iChill GeForce GTX 660Ti HerculeZ 2000s arrives. Game performance and image quality has received a tremendous boost, enabling film-like geometric realism for game characters and objects. Geometric realism is central to the GTX 670 architectural enhancements for graphics. In addition, PhysX simulations are much faster, and developers can utilize GPU computing features in games most effectively.
Features:-
- Duel cooling, less noise, better cooling, longer lifespan
- HerculeZ cooling technology speards heat from the side panel of the case, ensuring effective air flow than standard cards which flow out the back.
- HerculeZ cooler ensures loading tempreature is maintained below 65c when in the heat of battle.
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
Specification:-
- Memory Clock: 3004 (6008) MHz
- Height: 3-slot
- Connectors: 1x DisplayPort, 1x HDMI 1.4a, 2x DVI (Dual Link),
- SLI Ready (Upto 2-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Power Recommended power supply: min. 500 watts
- Dimensions: 202(W) x 111(D) mm
- Warranty: 2 Years
ORDER NOW
KFA2 GeForce GTX 660TI EX OC 2048MB GDDR5 PCI-Express Graphics Card with a free copy of 3DMark advanced edition @ £199.99 inc VAT
The KFA2 GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1084MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- TDP: 150W
- Warranty: 2 Years
ORDER NOW
MSI GeForce GTX 660Ti Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
The MSI GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1097MHz
- Shader Clock: 2038MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- TDP: 150W
- Warranty: 3 Years
Only £209.99 inc VAT.
ORDER NOW
really don't see the point in this type of pricing .. knock then down another £40 then we might start talking a "maybe" purchase .. will have to see after ive got the rest of my kit
They'll price them to whatever they can sell them at, and with the minor performance difference between this and the new card they'll sell at this price.
I bagged an end of life GTX480 as a bargain from another retailer last summer, the 500 series cards and now the 600 end of life stuff has not been so reduced, as ever I will wait it out until I am happy I have a bargain.
Its simple, if people buy then demand will keep the prices up, if you don't, they will drop, it not like petrol or diesel, you have a good deal of choice.
On a side note, the current this week only Gigabyte WF3 2Gb 770 is quite a steal if you want to spend over £300!
The problem is that despite we call the 600 series EOL, and the 700 series being "new gen", the truth is the move from the 600 series to 700 series (660Ti to 760, 670 to 770) with the small improvement feel more like 9800GTX to 9800GTX+, GTX260 192 to GTX260 216, GTX280 to GTX285 kinda replacements. The whole "new gen" thing really serve more as a marketing move more than anything else.
Pretty much hits the nail on the head, this is the opening line from the Hexus GTX 760 review:
"Those folk over at Nvidia sure know how to wring the most out of a particular graphics processing unit."
If they wanted to stick with the old naming system the 780 could pretty much be the GTX 685 and so on, 600 series to 700 series really isn't a 'new generation' if you ask me.
I miss the days when Gibbo used to be able to get EOL products in at bargain basement prices. Like that ole 5850 saga a while ago and those 480s. I fear the man has peaked too soon and has nothing left. :p
If the deals are not being offered, they are not there. So many companies going bust most have got a lot better with their stock control and no one is so willing to sell out a loss any more in order to gain revenue.
Though I shall remind you that OcUK was first on the 680, 670 and 660ti price drops, so if I have nothing left, my competitors must be in wooden boxes. :D
What's going on here OCUK?
I thought these prices were here to stay? I guess not????
Some of the 660Ti seem to have gone up (MSI & KFA), I've put them back down to match this thread.
670's are now nearly sold out, hence prices increased on what is remaining to help reduce our losses on them. Which is just business sense, why sell them at £20 loss per card if we can still sell out at just £10 loss per card. When loosing money we have to make the best business decision, especially when the stock will still sell and it won't be replenished.
I was mega happy that I could get my gtx 660ti (for sli) at the reduced price.
It just had to be snapped up as the value was great.
Now the games can be at max settings with good fps, looks awesome.
