NVIDIA graphics card with DVI-D port
22 Jun 2018
Hi
Im looking for a NVIDIA graphics card on this site with a DVI-D port.
I currently have a 2048MB ATI Radeon RX 460 Graphics (Gigabyte) card.
Thanks. :)
Thanks a lot ubersonic where could I buy SL DVI-D cable?
Er.
You should have one already if you were using a DVI cable to connect your RX460 to your monitor (it may even be a dual link cable).
*EDIT*
Just so we can both be clear about what we're saying here, below is the two main types of DVI connector found on graphics cards today:
The top is DVI-D (DL) which is found on new graphics cards, it only outputs digital signals, the bottom is the DVI-I (DL) connector found on older cards which also outputted an analogue signal that allowed the use of DVI to VGA adaptors.
This is what the pins on a DVI to VGA adaptor looked like:
Finally, below is what the really old (10 years plus) Single Link (SL) DVI-D and DVI-I cables look like (the original DVI cables have less bandwidth than the later dual link ones, they won't go above 1080p IIRC)
