nvidia gtx 970 fit in htpc case
16 Sep 2012
Hi
Just bought a zalman HD160XT of eBay on the cheap.
Missus not keen on my usual big builds so I'm building a htpc for gaming to.
Can anybody tell me if a nvidia gtx970 can fit in this case.
I think I'm reading I can but just asking in case somebody has owned
One of these cases and can give me a definate answer.
Thanks
Hi
Thanks
this one should fit
YOUR BASKET
1 x Gigabyte GeForce GTX 970 "Mini-ITX" 4096MB GDDR5 PCI-Express Graphics Card (GV-N970IXOC-4GD) £259.99
Total : £269.59 (includes shipping : £8.00).
I Have the Gigabyte GeForce GTX 970 "Mini-ITX & Gigabyte GeForce GTX 970 G1 Gaming FULL SIZE , Only difference is the Mini itx as alittle lower on core base clock
, if needed you can easy oc alittle to the full size 3 fan G1 From gigabyte
Mini itx runs 14Db lower than reference in 3D gaming :)
How noisy are they mate?
PLAYING Middle-earth Shadow of Mordor on max settings 1920 X1080
very little noise when putting your ear up to my case :Lian Li PC-Q33WB Mini-ITX Cube - Black Window , i have more sound coming from my psu :Silverstone Strider Gold Series - 850 Watt (SST-ST85F-GS)
so alittle noise at most when underload
Cheers I shall go for it then :-)
