Nvidia Monitor Crashing
18 Sep 2006
Dont know if anyone else has had this.
When I try and run NVidia Monitor I get the window come up (without any data in it) but then I get a "Nvidia Monitorview has encountered a problem and needs to close"
I have a Palit 8800GTS 640Mb
Forceware 97.92
NTune 5.05.25
Graphics are running fine. Never o/clocked etc. Speedfan reports the temp at 47 degrees C
What chipset does your mobo use? Maybe it's not be compatible with nTune.
There are other programs that can give you the same info, like rivatuner, so nv monitor isn't needed.
