- 12 Jan 2006
Hi All. Just built a new Uber Rig (See sig) and I am getting some interesting information from the Application, Nvidia Monitor that came with the Motherboard. It is showing the following as red for voltages
HT(SPP-MCP) 1.45
PCI-E 1.5
Now the Tooltip is stating that the component may be overstressed and this may lead to damage to my system. Is there anyone with a similar system to mine that can shed some light on this? Also the Memory has 2.1V and is shown as yellow. Again should I be worred about this. Everything else is Green
Ambient Temp is 28 Degrees
CPU temp is 45 Degees
GPU temp is 50 Degrees
That was after playing FEAR with everything on MAX for 30 minutes (Although The Temps were checked about 15 minutes after I closed the game down)
While I am at it are these temps ok?
HT(SPP-MCP) 1.45
PCI-E 1.5
