Nvidia Monitor Refresh Rate OC
15 Jun 2012
Hey guys.
You probably all know that the Nvidia Control Panel lets you set custom resolutions with various non-stock settings. I was vaguely aware of this but thought it was more for professional users or guys with nice, expensive monitors.
On a whim last night, I was playing around with boosting the refresh rate of my thougroughly unremarkable 2 year old Asus VE247H which runs 1080P at 60Hz stock. I was surprised to find that even with this cheap old monitor and a smomewhat dated GTX580, I was able to get to 74Hz at 1080P. Just under a 25% improvement.
Some brief ingame tests were pretty good, subjectively. I'd need to do a blind test to see how much of a difference it really makes.
Has anyone else done this? I'm sure most probably have as it sort of passed me by. I trust I'm not ruining my monitor or anything by running at a higher refresh rate. I guess it wouldn't work (as it doesn't with anything higher than 74Hz) at all if something was going really wrong.
TL;DR If your setup allows it, try and boost your monitor refresh rate in the NCP, even if you think your monitor isn't up to much.
Have you checked for frameskipping? - usually pretty easy to check for as just moving the mouse rapidly left to right a few times at 60Hz and again at the "overclocked" Hz usually shows its fairly plainly.
Suprisingly there are some older panels that will do ~75Hz fine without any frameskipping/interleaving and with a noticeable boost in responsiveness.
