Hi
Im thinking of getting the Nvidia nForce 650i Ultra to run an e2140 overclocked to 2.66MHz
I read this though in a review
'The Northbridge cooler isn't completely independent for its cooling abilities though. While a passively cooled chipset is attractive from a silent PC builder's point of view, this cooler is dependent on airflow from the main CPU cooler to keep temperatures in check. In order to keep some amount of airflow, the BIOS of this motherboard forces CPU fan speeds at 75% at a minimum. If you put in a high-end dual core (2.93 GHz or higher), a quad-core processor, or overclock the board, the BIOS will force the CPU cooler to run at full speed at all times, in order to help keep the chipset cool as well. Unfortunately, this means that if you're running a higher-powered system or tweaking it, you'll have to put up with loud fan speeds in order to keep the chipset in check. Of course, if you use third party fans/coolers, you can avoid this issue, but this does tell us that the chipset could likely overheat unless it receives some sort of ambient airflow'
I would like to get a cpu cooler in the future just to make the system quieter (not to cool it for major overclocking), but according to this - you cant turn down the fan speed!
Is that right?
Would this be better
http://www.ocworkbench.com/2007/ecs/NF650iSLIT-A/g1.htm
Uses same chipset (and BIOS right?) It has a fan on the northbridge I think. Dont know anything else about it.
thanks
Masten
Is that right?
thanks
Masten
