Hi,
i imagine this topic has been covered, but i cant find much on it, if it has been covered a very short and sweet answer would be much appreciated!
What are the differences?
Does matter which card family you use?
You dont have to use AMD cpus with ATI gpus, and intel cpus with Nvidia gpus do you? I think they are interchangeable, but would like confirmation.
As far as i can see the only differences between the two is the nvidia CUDA -
IIRC this allows programs which are CUDA enabled to use the GPU for processing. But as far as i know there are very few of these programs (Premiere CS5 is the only one i know of), so i dont think it really matters.
(im putting together a spec and deciding on a GPU for around £130-£200 you see).
Hope you can help
HOPE YOU HAD AN AMAZING CHRISTMAS!!!
Hope you can help
