anyone have any experience with FSX and gpu issues?? here's my story, well worth taking into consideration if building a system for Microsoft Flight Sim X.
As per my sig my sytem should be more than capable of playing FSX without any problems and it does now but not before I repaced a 4870x2 with a GTX 260! go figure.. well turns out it's all to do with the way in which ATI cards are structured and subsequently handle weather in FSX and the anti ailasing is also of next to no use in the sim. when selected my frame rates dropped to an unplayable 7-10 fps. Now there is a lot of tweaking that can and does need to be done in fsx settings to improve this and I'd encourage anyone to make sure they experement. It's also worth noting that FSX does not engage a 2nd GPU either from an X2 or X-fire/sli setup amnd also that the sim is very CPU hungry so get a good quad core and at least 4GB Ram.
So in short I bought a GTX 260 from OCUK for under £115 and problem solved, playing on very high settings ( allbeit with some tweaking) however my average FPS is 45+ and the sim is smooth as... And my other games are all very playable using this card.
