Nvidia Quadro 260.78
Caporegime
8 Sep 2006
On Ocuk
http://www.nvidia.com/Download/Find.aspx?lang=en-us
win7/vista x64:http://www.nvidia.com/object/quadro-win7-winvista-64bit-260.78-beta-driver.html
win7/vista 32:http://www.nvidia.com/object/quadro-win7-winvista-32bit-260.78-beta-driver.html
xp:http://www.nvidia.com/object/quadro-winxp-x32-260.78-beta-driver.html
xp x64:http://www.nvidia.com/object/quadro-winxp-x64-260.78-beta-driver.html
Windows 7 64BIT Modified Driver Inf ( overwrite old Inf in unpacked driver folder )
http://www.datafilehost.com/download-a7642aa4.html
Previous version was buggered with international driver , works fine with English(US) :banana:
Support for newly announced Quadro 2000, and Quadro 600.
Adds support for CUDA 3.2 for improved performance in GPU Computing applications. See www.nvidia.com/cuda for more details.
Installation
The driver installer has been updated with an enhanced user interface, improved
installation time for multi‐GPU PCs, and new Express and Custom installation options
Express – one-click installation
Custom – customized installation
Option to perform a clean installation (completely removes older drivers from your system prior to installing the new driver)
Option to choose which driver components (ie. PhysX or 3D Vision) to install
NVIDIA Control Panel Updates
General Interface
Removed the Views option to simplify operation. You no longer need to select between Standard and Advanced views for many NVIDIA Control Panel controls.
Removed the Profile menu.
Display Category
Set Up Multiple Displays page
Added drag ‘n’ drop capability to the display icons so you can arrange the icons to match your display position
Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
If you would like to be notified of upcoming drivers for Windows, please subscribe to the newsletter.
Existing Support:
Support for the Open Computing Language (OpenCL) 1.0
Supports NVIDIA SLI technology (two-way SLI) for DirectX 9, DirectX 10, and OpenGL on SLI-certified Intel X58-based motherboard based system from select OEMs.
Support for DDC-Ci/MCCS over the DisplayPort AUX channel.
10-bits per color (10bpc) DisplayPort support for full-screen applications on supported products.
Support for OpenGL 4.0
Support for DirectX 11
EDID Management
Accessible from the View System Topology page, this feature lets you:
View the connector information
Get an EDID from a connected display and save it to disk
Force an EDID at a connector
Remove a forced EDID from a connector
Just waiting on the inf's to use them on other cards and yes that does work for most
It may mess up (only while using these drivers) SLI configuration for some users (minority).
If your having issues worth giving it a try - otherwise I'd wait for the GeForce WHQLs.
quadro drivers are for quadro cards. they will be optimised to work with quadro cards.
why would you use a quadro driver for a geforce card? no point at all. and the chance that something won't work is higher.
Not going to argue with you , don't want to use them then don't!
Some of the best drivers have been quadro's :)
Furmark , Heaven , Vantage i've lost a frame here or there , nothing to worry about
Games all working fine
Do you have Mass Effect?
If so, do these drivers cure the graphical glitches that the 260.63 beta's cause?
