NVIDIA Quadro 266.45 WHQL
Caporegime
8 Sep 2006
On Ocuk
DriverVer = 12/27/2010, 8.17.12.6645
New in Release 266.45:
* Support for newly announced NVS 300
* CUDA 3.2 for improved performance in GPU Computing applications. See www.nvidia.co.uk/cuda for more details.
* NVIDIA Mosaic
o This release introduces the new NVIDIA Mosaic Technology, supported only under Windows 7.
* NVIDIA Control Panel Updates
o General Interface
1. The System Information page now shows the DirectX version supported by each GPU
2. Added Multi-GPU Visual Indicator
o 3D Vision / Stereoscopic 3D
1. Added 3D Vision Pro controls for use when a 3D Vision Pro hub is connected.
2. Added stereoscopic 3D windowed mode support for select 3D programs, including Google Earth
* 3D Vision
o Added support for 3DVisionLive.com Beta2
1. Supports 3D photo sharing and viewing
* Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
Existing Support:
* Support for the Open Computing Language (OpenCL) 1.0 in Quadro FX Series x700 and newer as well as the FX4600 and FX5600.
* Support for OpenGL 4.1
* Support for Directx11
XP 32BIT
http://us.download.nvidia.com/Windo...45/266.45-Quadro-winxp-32bit-english-whql.exe
XP 64BIT
http://us.download.nvidia.com/Windo...45/266.45-Quadro-winxp-64bit-english-whql.exe
32BIT VISTA/7
http://us.download.nvidia.com/Windo...5-Quadro-win7-winvista-32bit-english-whql.exe
64BIT VISTA/7
http://us.download.nvidia.com/Windo...5-Quadro-win7-winvista-64bit-english-whql.exe
64BIT Modified Inf.
http://www.mediafire.com/?tf8119gckauzb58
Just waiting for the latest INF mod for all cards!, I'll only use Quadro drivers as imo they are much better drivers!
Download Driver - Unpack Driver - Download Inf - Copy/Overwrite Inf into Drivers folder - Run setup
Sadly these crash for me as well. Thirty seconds into Bad Company 2 & the driver crashed.
These don't hold an OC.
These look better and run better in black ops.And seem to be higher fps too.
Kinda expected that, the overclock crash and high AA issues, were only really discovered after the 266.35 drivers were released in 2011, and these drivers are from Dec 27th.
Considering it takes a while for WHQL cert, i wouldn't expected a WHQL with these fixes to appear for a week or two at least.
:D:o:(:eek:
