Nvidia Quadro Driver v267.66 WHQL
Caporegime
8 Sep 2006
On Ocuk
DriverVer = 03/10/2011, 8.17.12.6766
WINXP 32BIT
http://us.download.nvidia.com/Windo...adro-winserv2003-32bit-international-whql.exe
WINXP 64BIT
http://us.download.nvidia.com/Windo...adro-winserv2003-64bit-international-whql.exe
WIN7 32BIT
http://us.download.nvidia.com/Windo...adro-winserv2008-32bit-international-whql.exe
WIN7 64BIT
http://us.download.nvidia.com/Windo...ro-winserv2008r2-64bit-international-whql.exe
New in Release 267.66:
* Support for the newly announced Quadro 2000D
* CUDA 3.2 for improved performance in GPU Computing applications. See CUDA for more details.
* NVIDIA Mosaic
o This release introduces the new NVIDIA Mosaic Technology, supported only under Windows 7.
* NVIDIA Control Panel Updates
o General Interface
1. The System Information page now shows the DirectX version supported by each GPU
2. Added Multi-GPU Visual Indicator
o 3D Vision / Stereoscopic 3D
1. Added 3D Vision Pro controls for use when a 3D Vision Pro hub is connected.
2. Added stereoscopic 3D windowed mode support for select 3D programs, including Google Earth
* 3D Vision
o Added support for 3DVisionLive.com Beta2
1. Supports 3D photo sharing and viewing
* Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
* If you would like to be notified of upcoming drivers for Windows, please subscribe to the newsletter.
Existing Support:
* Support for the Open Computing Language (OpenCL) 1.0 in Quadro FX Series x700 and newer as well as the FX4600 and FX5600.
* Support for OpenGL 4.1
* Support for Directx11
WILL UPDATE WHEN INF FOR ALL NVIDIA CARDS IS AVAILABLE!
Do these beat 266.59 drivers for 550 Ti?
They're what I'm using now and they're the best drivers I can get on my 570 for DA2.
I cant find 267.66 drivers anywhere.
Does anyone have a link or hint on what site they're on, ta.
:confused::confused:
You're the second person to ask that, it's right in bloody front of you first post :p
Perhaps the CODE is blocked on some peoples systems?, i'll remove it
Does DA2 play on very high with high res textures with these?
Yes. But the actual DA2 bugs are still there like odd crashes and black floors in the shape of polygons outside of the city in certain areas.
Basically the games DX11 engine is borked.
(Waits for patch)
