Nvidia Quadro?
Man of Honour
19 Oct 2002
Surrey
Can anyone explain in simple terms what the difference is between the normal nVidia laptop GPU's (8600GT, GT130, etc, etc) and the Quadro line (such as Quadro NVS 140M). How do they compare on performance? I'm guessing that the Quadro line is the business range and so is unlikely to be as quick?
The reason for asking is I'm looking at a possible refurbished Thinkpad T61 with a Quadro NVS 140M 128mb. Would I be correct in assuming that this will be incapable of playing any games? I'm not after a games machine but it's still interesting to know.
It seems Quatro is more for design and image quality rather than frame rates.
Here is a quote from there website "Dynamically scale graphics performance, enhance image quality by combining two Quadro® FX 4800 graphic cards by uniting them as a single graphics card within a ThinkStation D20 system.
* SLI Frame Rendering: Transparently scale application performance that benefits visual simulation, broadcast and video applications which are fill rate-limited, using the Split Frame Rendering (SFR) mode SLI Full Screen Anti Aliasing (FSAA): Transparently scale image quality. FSLI FSAA increases the FSAA level up to 32x to remove jaggies from contours of geometries in real time that benefits design review and Digital Mockup (DMU), visual simulation, broadcast and video applications."
And some Q&A from the same site and i feel this shud give you a good grasp of the difference between the two.
http://www.nvidia.com/object/quadro_sli_faq.html
The main problem with the Quadro NVS 140M and gaming would be the very slow memory.
Although quadro cards are built for professional features and quality over performance they aren't really that much slower for gaming purposes... infact you can probably spoof the device ID with rivatuner and install regular drivers and for gaming intents and purposes would be identical to the geforce...
However the Quadro NVS 140M isn't going to cut it for many games released in the last 3-4 years.
i find quadro drivers work great with certain gpus,even better than nvidia forceware,you need a modded inf,which can be easily made by yourself,i get better fps on games with quardro drivers
