NVIDIA RTX 50 SERIES - Technical/General Discussion
Unbelievable. Yet Nvidia keep persisting with this stupid connector.
BUT BUT It's user error.. :rolleyes:
Still shocked they have not been recalled or some legal action taken regarding this dangerous connector. Even AMD cards with this connector have had the same issue with a lot less wattage cards. I am now starting to think this was done by purpose and by design to add another planned obsolescense feature.
Think my GPU is broke. Booted into a black screen. Motherboard post code is 9C which is reported to usually be USB device issue. Unplugged all USB but same issue.
Plugged my monitor into the onboard vga and i can boot and see windows. Windows is reporting a code 43 error on my 5090.
I have tried:
Reconnecting the power cables
Reseating the card
Cleared CMOS
Safe mode DDU to uninstall the nvidia drivers
Rolled back drivers (although this never happened after a driver update).
Tried changing PCIE link speed in the bios.
Turned off fast boot
Anyone have any other suggestions for me to try?
I have tried:
Reseating the card
Cleared CMOS
Did you try another GPU? It could be the slot, or your GPU. Sorry to hear. This issue happened with my 5090 FE.
The onboard works. Can't easily try another slot at the moment due to waterloop and not enough slack to move the card over. When i have more time this evening i will drain the loop and try a different slot.
So far the smartest way to deal with that connector issues but reality is it needs to be replaced with something safer. If you understand how electricity works you will understand the reason of 48V used if not you will not understand the "fix" is actually safer than 12V currently used.
Due to less current at 48v presumably?
Way too much hassle trying to do it peace meal. Its just Asus spending some of its RnD budget that it has from its overpriced products
If they release a GPU that runs on 48v, you'd need a new PSU to go with it as well
I'd love to see the PCB of that 48v ASUS card cause the GPU will still be near 1v under load right, so now the VRM on the PCB needs to convert 48v to 1v instead of 12v to 1v, so theoretically you need better VRMs
