- 27 Jul 2005
- The Orion Spur
anyone else got this problem (8800gtx/gts users) with the nivida scaling options,
I select the option 'Use my display's built-in scaling' and click apply but as soon as you exit the options and go back in it has reverted back to 'Use NIVIDIA scaling' which is really annoying as I can't use my monitors 1:1 pixel mapping, infact any option other than 'Use NVIDIA scaling' just does'nt stay selected
could someone check if they have the same problem also and if not what driver version are you using.
