- 11 Dec 2005
- Cheshire
We have teamed up with Nvidia to introduce to you some of the finest SFF LAN based systems, ideal for playing the latest games such as COD:Ghosts & BF4.
Available with the exclusive Nvidia vinyl graphics and the Nvidia game bundle.
Click here
"GeForce Gamer" Intel Core i5 4670 3.4GHz (3.8GHz Turbo) Quad Core Nvidia GTX Gaming PC with Free Games @ £778.98 inc VAT
Introducing the "GeForce Gamer" Nvidia GTX based Small Form Factor Gaming systems. Developed to deliver maximum performance from a minimal sized chassis, designed hand in hand with Nvidia GeForce graphics cards for a truly impressive gaming experience.
Packing an Intel Core i5 4670 Quad Core CPU running at 3.8GHz paired with 8GB of 1600MHz DDR3 memory, the heart of a "GeForce Gamer" system is a strong one! Supplying the system with enough processing power, to play even the most demanding games effortlessly.
Mini ITX form factor allows for a discreetly small chassis to be chosen fitting in with the portable LAN gamer feel. Being able to take your system to LAN events easily is a major plus point, why cart around a huge tower system when you can have one with just as much power, yet half the size?! Noise levels have been taken into consideration too, with every "GeForce Gamer" system developed in a noise sensitive environment to deliver a near silent operating volume. On par with the latest gaming consoles.
Graphics card duties in the "GeForce Gamer" are managed by no other than Nvidias own GeForce graphics cards. Choose from either a; GTX 650 1GB, GTX 650Ti Boost 2GB or GTX 660 2GB, all capable of delivering sublime DX11 graphics. For more demanding games select a graphics card with a higher capacity of VRAM. OcUK recommends the GTX 660 2GB for the "GeForce Gamer" system.
Equipped with a 1TB Seagate HDD as a default option, offers ample storage. However should you require more space, we have a multitude of options for you to not only increase storage capacity but to add an SSD as a boot drive. OcUK recommends selecting an additional 120GB SSD if you wish to increase the boot up and file transfer times of your system.
To make your system truly unique, each case is finished off with a Limited Edition Nvidia GeForce vinyl kit. Stand out from the crowd with your pocket rocket "GeForce Gamer" system, designed by gamers, for gamers
Get this season's best bundle of Assassin's Creed IV: Black Flag,
Why You Should Buy This System?
- Quad Core processing & 8GB of DDR3 memory
- Micro ATX size for ultra portability and discreetness
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- Very powerful Nvidia GeForce GTX 660 2GB with DX11 capable graphics card
System Specification
- Case: Bitfenix Prodigy Micro ATX Gaming Case - Black with Nvidia Customisation kit
- Power Supply: Premium 500W 80+ Rated Power Supply
- CPU: Intel Core i5 4670 3.40GHz Haswell Processor with Turbo enabled to 3.8GHz
- Motherboard: Asus H81M-E Micro ATX Gaming Motherboard
- Cooler: Intel CPU Cooler
- RAM: 8GB 1600MHz DDR Dual Channel Memory
- Hard Drive: Primary and Secondary SSD & HDD Options Available
- Graphics Card: Nvidia GeForce GTX 660 OC 2GB Graphics card
- Sound: High Definition 7.1 Onboard Sound Card
- Operating system: Windows 8.1 64 Bit with GeForce Experience Pre-Installed
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
Only £778.98 inc VAT.
ORDER NOW
"GeForce Premium" Intel Core i5 4670 3.4GHz (3.8GHz Turbo) Quad Core Nvidia GTX Gaming PC with Free Games @ £989.99 inc VAT
Introducing the "GeForce Premium" Nvidia based Small Form Factor Gaming systems. Developed to deliver maximum performance from a minimal sized chassis, designed hand in hand with Nvidia GeForce graphics cards for a truly impressive gaming experience.
Packing an Intel Core i5 4670 Quad Core CPU running at 3.8GHz paired with 8GB of 2133MHz DDR3 memory, the heart of a "GeForce Premium" system is a strong one! Supplying the system with enough processing power, to play even the most demanding games effortlessly.
Mini ITX form factor allows for a discreetly small chassis to be chosen fitting in with the portable LAN gamer feel. Being able to take your system to LAN events easily is a major plus point, why cart around a huge tower system when you can have one with just as much power, yet half the size?! Noise levels have been taken into consideration too, with every "GeForce Premium" system developed in a noise sensitive environment to deliver a near silent operating volume. On par with the latest gaming consoles.
Graphics card duties in the "GeForce Premium" are managed by no other than Nvidias own GeForce graphics cards. Choose from either a; GTX 760 2GB, GTX 770 2GB or GTX 780 3GB, all capable of delivering sublime DX11 graphics. For more demanding games select a graphics card with a higher capacity of VRAM. OcUK recommends the GTX 770 2GB for the "GeForce Premium" system.
Equipped with a 1TB Seagate HDD and a 120GB SSD as a default option, offering ample speed & storage. However should you require more space, we have a multitude of options for you to not only increase storage capacity. OcUK recommends selecting a larger SSD if you wish to increase capacity whilst maintaining the fast boot up and file transfer times of your system.
To make your system truly unique, each case is finished off with a Limited Edition Nvidia GeForce vinyl customisation kit. Stand out from the crowd with your pocket rocket "GeForce Premium" system, designed by gamers, for gamers.
Get this season's best bundle of Assassin's Creed IV: Black Flag, Tom Clancy's Splinter Cell: Blacklist and Batman Origins free with the purchase of this gaming PC, whilst stocks last.
- Quad Core processing & 8GB of fast DDR3 memory
- The latest, fantastically powerful Nvidia GeForce GTX 770 2GB with DX11 capable graphics card
- Power Supply: Premium 600W 80+ Rated Power Supply
- RAM: 8GB 2133MHz DDR Dual Channel Memory
- Graphics Card: Nvidia GeForce GTX 770 2GB Graphics card
- Sound: High Definition 7.1 Onboard Sound Card - Operating system: Windows 8.1 64 Bit with GeForce Experience Pre-Installed
Service Package
Only £989.99 inc VAT.
ORDER NOW
"GeForce Ultimate" Intel Core i7 4770 3.4GHz (3.9GHz Turbo) Quad Core Nvidia GTX Gaming PC with Free Games @ £1,600.00 inc VAT
Introducing the "GeForce Ultimate" Nvidia based Small Form Factor Gaming systems. Developed to deliver maximum performance from a minimal sized chassis, designed hand in hand with Nvidia GeForce graphics cards for a truly impressive gaming experience.
Packing an Intel Core i7 4770 Hyperthreading Quad Core CPU running at 3.9GHz paired with 16GB of 2133MHz DDR3 memory, the heart of a "GeForce Ultimate" system is a strong one! Supplying the system with enough processing power, to play even the most demanding games effortlessly.
Micro ATX form factor allows for a discreetly small chassis to be chosen fitting in with the portable LAN gamer feel. Being able to take your system to LAN events easily is a major plus point, why cart around a huge tower system when you can have one with just as much power, yet half the size?! Noise levels have been taken into consideration too, with every "GeForce Ultimate" system developed in a noise sensitive environment to deliver a near silent operating volume. On par with the latest gaming consoles.
Graphics card duties in the "GeForce Ultimate" are managed by no other than Nvidias own GeForce graphics card. Armed with an Nvidia GeForce GTX 780Ti 3GB card as standard. No other than Nvidias, flagship single GPU card, designed with one task in hand, to play games to the max!
To make your system truly unique, each case is finished off with a Limited Edition Nvidia GeForce vinyl case customisation kit. Stand out from the crowd with your pocket rocket "GeForce Ultimate" system, designed by gamers, for gamers.
- Quad Core processing & 16GB of fast DDR3 memory
- The latest, fantastically powerful Nvidia GeForce GTX 780Ti 3GB with DX11 capable graphics card
- CPU: Intel Core i7 4770 3.40GHz Haswell Processor with Turbo enabled to 3.9GHz
- Motherboard: Asus Z87 Gryphon Micro ATX Gaming Motherboard
- RAM: 16GB 2133MHz DDR Dual Channel Memory
- Graphics Card: Nvidia GeForce GTX 780Ti 3GB Graphics card
Service Package
Only £1,600.00 inc VAT.
ORDER NOW
Click here
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
