Can't find a solution anywhere for this so thought I would ask here, you never know.
I have a 2019 Shield with the new remote, I want the power button to ONLY turn off the TV, not put the shield to sleep as its causing issues with my hard drives that are plugged in randomly not working until I restart the shield (Kodi crashes if I try to wake the hard drives through there)
Was never an issue with the Raspberry Pi 4 this replaced as it couldn't go to "sleep"
No combination of options in the menu's allows this to happen, it will always put the shield to sleep, I don't want it to do this.
Does anyone know of any clever trick to disable it sleeping when you press the power button?
Thanks
Thanks
