nvidia shield tv power adapter depth?
30 Jul 2005
Midlands
does anyone have the measurements of the nvidia shield tv power adapter mainly the depth? id like to see if its going to fit behind the wall mounted tv that has power socket directly behind the tv.
The 2015 or 2017 version? I've got the older one and could check for you later if you still need to know?
2017 one is 45mm deep, 48mm wide and 70mm high. That's from the plug socket face with it plugged in.
thanks for those measurements. as i suspected its too deep and the tv wont go back on the wall (power sockets are behind the tv.)
going to have to think of something else to get the shield tv to work. will see if i can use a short extension and relocate to the side of the tv.
