Nvidia Shows Impressive GameWorks Flow Tech
30 Mar 2010
Under The Stairs!
Today Nvidia released a video demonstrating its 'Flow' technology, joining the GameWorks suite to simulate combustible fluid, fire and smoke. You can check out the video below, running in DirectX 12, even if the tech works in DirectX 11 as well.
http://www.ggmania.com/?smsid=nvidia-shows-impressive-gameworks-flow-tech-43173#.WPkmttIrKUk
NVIDIA Flow is a realtime fluid simulation - in this demo, simulating fire and smoke. The simulation is based on an adaptive sparse voxel grid, allowing the simulation to focus compute and memory resources around regions of interest, and track shifts in the region of interest over time.
With the fire, the combustion process is simulated per voxel, generating elevated temperatures and smoke, which influences the visual appearance and produces buoyancy and expansion effects on the fluid simulation.
An adaptive sparse voxel grid is also used to compute self-shadowing on the smoke, increasing both the realism and visualizing the structure of the smoke. The fluid simulation supports real time collision with objects in the environment, along with fuel emitters than can be modified in real time, making the simulation fully interactive.
For more information on the Flow library:
https://developer.nvidia.com/nvidia-flow
Would love to see some of this in games.
Can't wait till games use stuff like this for water - nothing worse than a great looking scene then you notice the billboard sprites use for a waterfall, etc.
Nvidia continuing to innovate.
Tbf you see this sorta stuff all the time. Especially when you see new engines being shown off but the hot
Horsepower needed is usually ridiculous. Its only a real innovation when its delevoped where devs can make use of it and dosnt cause a massive performance hit. As generally speaking a lot have mid ranged systems and it can make fps tank which kinda ruins things. So as long as this dosnt take a massive hit on performance then lll consider it innovation.
I used to turn godrays off in fallout for example because the performance hit was not worth the little iq it added.
I'd much prefer this done in engine, like Source games with Havok. I even turned all the gameworks stuff off in Killing Floor 2 because of the poor performance.
Alpha effects have always been the biggest bandwidth sapping, frame rate killing effects in games.
Yup, in the Division when there's a Contam Event and loooooooots of fire and explosions going on my fps still tank! Usually a solid 75 running 3840x1600@Ultra though so I can't complain too much.... :cool:
And it looks fantastic too :D
Voxel-based effects are incredibly costly. But super cool.
Should Moore's Law not completely stall out in the near future, I think voxel-based graphics will become very popular for pushing advanced visuals with complex physics.
Are AMD able to do Voxel or is this Nvidia only?
Nothing stopping anyone using sparse voxel octrees in their game - though when used for a rendering effect fully optimised on a hardware vendor basis I believe nVidia has some acceleration available at hardware level that helps (its likely the changes in Vega will include similar).
AMD's typically wide architecture kind of naturally works well with that kind of stuff but I don't believe they've paid any attention to that type of use specifically.
Well there is a big step from the basic mechanics through to actually using it for something like in this case fire rendering.
So really Nvidia putting the word GameWorks next to it is a bit misleading then?
What do you mean? Gamesworks is just a collection of graphical effects that developers can incorporate freeing up resources. Most games works effects have always run on AMD hardware
Ignore me. I was getting two things mixed up. I asked a question about Voxel and then replied talking about Gameworks in context of this fire demo.
I'm tired, it's a Fri. I need sleep. :p
