Nvidia Smooth Motion?
Can't anybody do a search anymore? This took seconds to find. Read the full article here.
Nvidia Smooth Motion Now Available.
NVIDIA Smooth Motion is a new driver-based AI model that delivers smoother gameplay by inferring an additional frame between two rendered frames. For games without DLSS Frame Generation, NVIDIA Smooth Motion is a new option for enhancing your experience on GeForce RTX 50 Series GPUs.
To enable NVIDIA Smooth Motion, select a compatible DirectX 11 or DirectX 12 game in Graphics > Program settings. Scroll down the list of options on the right to reach “Driver Settings”, and switch Smooth Motion on.
“NVIDIA Smooth Motion is a brand-new driver technology and requires time for validation and QA across multiple products. Support for GeForce RTX 40 Series GPUs will be coming in a future update.”
Makes sense, it's a simple software interpolation, doesn't use any the GPU hardware like frame gen
It's also coming to series 4000 at a later date
Someone doesn't read the thread :D
