Nvidia Surround! need help with monitors
10 Jan 2011
Hey guys n gals,
I need help and maybe someone can help me,
I'm looking to get nvidia surround I have Geforce 470 in SLI, but i'm now looking at monitors my current monitor is the samsung 2233 3D monitor,
Now should I just buy two more Samsungs 2233 for a total of £329.98
or
LG W2363 3D monitor x3 for a total of £467.
or
BenQ G2222HDL LED x3 for a total of £329
Both the LG and BenQ are 1920x1080 screens would it be a fast improvment on the Samsung? And the BenQ is a LED screen while the other two are LCD again would it be a fast improvement?
I have about £500 to spend on the monitors incase you find better options I really need help on this one guys.
Many Thanks
They're all LCD - the LED refers to the backlight, and there's no benefit over traditional CCFL backlights besides lower power consumption. CCFL backlights are sometimes better/more vibrant than LED, but don't buy one or the other based just on the backlight type.
Do you use 3D? If not, I'd be tempted to get three LG IPS231P monitors at ~£150 each, as they're IPS panels and have lovely image quality. I doubt you'd be able to utilise the 120Hz advantages of the 2233RZs.
I did use the 3D side of the Samsung, but after a while it starts to hurt my eye's so now it's more of a standard monitor but with 120Hz as you said,
I'll take a look at the LG's thank you for all your help.
