With the nvidia surround setup on the desktop, the 3 monitors are treated as one display.
When I launch a game/program/utility that only uses 1 screen (eg: 3dMark vantage / heaven) it always uses the far right screen
Is there any way i can change this to use the centre screen?
For benchmarking programs its ok, but for a game that wont support surround its not exactly viable.
Setup :
I have the middle screen plugged into the top card and the 2 side screens plugged into the bottom card.
My reasoning for this was to try and put less load on the top card, since that is the one starved for air in the sli and is 8* hotter by default anyway. (which could be failed logic anyway
Setup :
