- 19 Oct 2014
Hi Gang,
Just got my MSI GTX970, (zero coil whine btw
) and trying to set it up correctly. At the moment I have it running with my middle monitor as the main, with either side monitor extended desktop. This is working fine.
I next go into the control panel and select surround configuration. Now at this point things go wrong as my monitor layout which I have just set up to be centre with two extended now needs re-moving around so it is as the surround wants. This then works in surround.
If I then come out of the software and hit the ctrl, alt & s key to switch between, it comes out of extended fine, but then puts my right hand monitor as main, with the other 2 disabled. I then go back in and start again.... Hayelp!!
I have come from using an ATX card and you could set up different profiles within that but I just cannot get my head round this.
Cheers, me!
) and trying to set it up correctly. At the moment I have it running with my middle monitor as the main, with either side monitor extended desktop. This is working fine.I next go into the control panel and select surround configuration. Now at this point things go wrong as my monitor layout which I have just set up to be centre with two extended now needs re-moving around so it is as the surround wants. This then works in surround.
Cheers, me!
