- 29 Dec 2007
- London
Hi guys, I've got a slight problem with nvidia surround. I'm aiming for 5760x1080.
I had this working for around a week, but I've since re installed Windows 7, and I can no longer get it to work
With a fresh windows install, upon enabling surround it changes the resolution to 5040x1050, it won't let me add a custom resolution, "test failed". I assume 5040x1050 is the next best resolution in which the sync polarities match (+/-)
Gigabyte GTX 670
1 x Benq 2420HDBL - DVI
1 x Benq 2420HD - DVI
1 x Benq 2420HD - HDMI port--> DVI adapter
I haven't switched the cables since it worked, so it's not to do with that.
The monitors are pretty much identical, but it would seem the sync polarity is slightly different.
In Nvidia control panel I can add custom resolutions, which sets the sync polarities the same.
Standard:
1 x Benq 2420HDBL --> +/+
1 x Benq 2420HD --> +/-
I add a customer resolution to the control panel for the HDBL, it tests fine. But when trying to enable surround the screens flashes and then the box unticks itself. No errors, nothing in the event log.
Using a program (I've forgotten which) to read the EDID info the HDBL can support both types of polarities.
I've tried using moninfo.exe to create a custom driver but it just crashes when I launch the program (red screen). It seems it's happened to a few other people too. So that's out the window.
I've also tried replacing the windows Benq HDBL driver with the normal HD driver, but still have the same problem.
Any ideas? Other than purchasing another 2420HD ?
Gigabyte GTX 670
Standard:
