Nvidia Surround with Dual Monitors, Impossible?
Permabanned
3 Oct 2009
North Wales
I got a gtx 660 and I completely forgot to check if it would let me use surround with my dual monitors...looking online tells me that nvidia cards don't have the feature like amd cards do that lets you use surround on dual displays.
So is this completely impossible?
Any unofficial software that will let me do this, does displayfusion do this?
Thanks :confused:
I have Display Fusion and cannot achieve this. The only way I have managed to get it showing on two screens, is restoring then stretching the game screen over the two monitors. Just remember you will have the bezel down the middle so FPS games might put you off.
To answer the Nvidia Surround question, no. It does support dual monitors so if you wish to achieve it properly you will need 3 monitors.
