Hi Guys,
Current setup is in my Sig - I've been trying to setup Nvidia Surround I have the following;
2x Acer 24" Monitors.
1x Cinema HD Display 23"
All running at 1920x1080
5ms
All looks ok, Current configuration is;
2x Dvi
1x Dvi into Display port.
Now I believe that it wont work due to the difference between the Mac and the Acers.
I'm planning to get a 3rd Acer 24" next week, but im just slightly concerned that the Surround will still not work!
Is it ok to use a DVI - DisplayPort adapter will this allow Surround to work? as the Monitors only have VGA / DVI and I know VGA will not allow Surround!
Thanks,
Ryan.
5ms
2x Dvi
Thanks,
Ryan.
