Nvidia upgrade 8800GT/9600GT > ?
19 Oct 2006
Well I gave up baking my 8800GT so I am currently using a borrowed 9600GT which seems to be struggling with Alan Wake (on low settings but res is 1900x1200).
I have recently upgarded the rest of my machine with z68/2700k/16gb and can probably budget £80-£100 for a new nvidia gfx card, I would consider some thing off the mm if that would give me the best bang for buck.
Whats my best bet then guys, 460/470 ?
It would seem a shame to not add a decent GPU to such a good build. What games are you currently playing/intend on playing?
On a budget, sounds like you're either going over budget to stay in the Green team, or hop ship to the Red team.
I cant access the MM, but there is a new GTX460 SC for £125.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-171-EA&groupid=701&catid=1914&subcat=1830
Or stay on budget and get an equally good card (albeit AMD) for £93.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-163-MS&groupid=701&catid=56&subcat=1866
Quick compairson (i know it's not the SC, but close enough :P)
http://www.anandtech.com/bench/Product/291?vs=313
To be honest I don't often get to play games, having a go at Alan Wake and mainly only really play single player fps and the ME series.
Would defo like to stay green hence I think I'm looking at seomthing 2nd hand off the mm, is a 460 768mb a reasonable step up from a 9600GT, will I be able to play ok at medium settings 1920x1200? (say on alan wake for instance?)
Fair play and I understand your budget. The 460 will be fine but you will need to lower settings to make it playable.
