GK5CP6Z pc specialist NVMe issue
Hi all.
I was hoping someone could help. I have a 2019 PC specialist recoil. It has the i7 9750h and 1660ti.
The board has 2 NVMe slots and 1 SSD in which one of the NVMe ports is shared with the SSD.
On first boot everything worked fine. However once I allocated the space within disk manager and shut the laptop off the next time I came to turn it on the laptop wouldn't post.
I've tried swapping ports. Cloning the SSD to the NVMe tried with both installed and even a intel nvme. If there is a NVMe installed it won't post.
I've hot swapped the NVMe and it does show In windows. It also works fine with a caddy.
I've tried updating the drivers but no success. Tried secure boot on and off and checked im not running in legacy.
I've even tired to find a bios however been unable to find one. I'm currently on what is apparently the latest version of 1.04.
I'm currently unsure what else to try. Wondering if anyone else has had a issue like this and what your fix was?
Thank you.
Hi all.
Thank you.
