Is the best way to overclock my nvidia geforce 7900gs 512 ddr3 is with nvtray?
It gives me the option to manually overclock(there is no option to auto overclock
) and then detect optimal system, then I tick the box which applys the settings direct at startup. Yet it doesnt seem to do much and doesnt seem to increase the Core Clock Frequency too much.
It is currently at Core Clock Frequency 490, memory clock frequency 1.39 ghz. Is this good?, correct? should i change it, and is there a better program. Please help
System Specs:
CASE: AKASA ZEN MIDI ATX IVORY WITH 2 SILENT 12CM FANS AT FRONT AND REAR.
PSU: HIPER 580W PSU
CHIP: INTEL CORE2DUO E6600 2.4GZ
MOTHERBOARD: Gigabyte GA945P-S3 Socket 775 FSB 1066mhz
GRAPHICS CARD: NVIDIA GEOFORCE 7900GS WITH 512MB DDR 3 MEMORY, OVERCLOCKED USING NVTRAY
MEMORY: 2 GIG DDR2 DUAL CHANNELED 533MHZ SPEED, BOTH KINGSTON AND DELL (NOT SURE OF MAKE)
MONITOR: 17" DELL FLAT PANEL
SOUND: DELL 5.1 SPEAKER SYSTEM, 5 SPEAKERS AND SUBWOOFER.
OPERATING SYSTEM: WINDOWS XP MC EDITION 2005
) and then detect optimal system, then I tick the box which applys the settings direct at startup. Yet it doesnt seem to do much and doesnt seem to increase the Core Clock Frequency too much. It is currently at Core Clock Frequency 490, memory clock frequency 1.39 ghz. Is this good?, correct? should i change it, and is there a better program. Please help
System Specs:
PSU: HIPER 580W PSU
