NZXT 510 power button boots but does not shut down on hold
7 Nov 2005
Widnes
Hi,
I'm used to my case power button switching the unit on when I press it and then forcing a shut down when holding it. The NZXT 510 I've just built is switching the PC on but refuses to shut it down. Any ideas? I have put the whole F_Panel connector straight onto the motherboard rather than via the older spit connections.
I should note that I'm not seeing a display either at the minute but going through the usual steps like clearing CMOS, checking power connections, etc.
Ah, note to self - simply pushing the CPU power connector through from the back of the case during cable management stage does not magically connect it to the motherboard.
