Nzxt 630 question about the fan hub.
27 Mar 2013
Just a quick question about the fan hub on the back of the motherboard tray. What actually pores the fan hub? I take it it's the molex that's bundled up with all the USB and sound cables. Just want to check.
Top port on the fan hub connects to the fan controls on the top of the case.
Just connect the molex power from your PSU to the molex that is bundled with the front I/O cables (as you mentioned).
This powers both the fan controller and the lights on the top.
No problem, if you run into any trouble give us a shout.
Should be rather straightforward though.
