I have recently purchased an NZXT 820 from overclockers and have got the majority of my components inside of the case. However I have a few cables remaining at the back along with what I assume are the pre-installed fan cables as they are not working currently.
Some of the cables are labeled:
- POWER SW x 1
- RESET SW x 1
- HD AUDIO x 1
- H.D.D LED x 1
- IS x 1 (That I can see)
I then have some other cables with single letter labels such as 'R' and 'F' which I assume stand for rear and front. If you can give me any help with what I should be doing with these cables it would be massively helpful, especially with the fans.
Thanks -
- POWER SW x 1
- RESET SW x 1
- HD AUDIO x 1
- H.D.D LED x 1
Thanks -
