- 5 Feb 2008
Hey guys,
I'm considering upgrading my PC's case and this is what I've had in mind.
NZXT Apollo Black ATX
I was just wondering has anyone had this case and what they thought of it, I've read some reviews but I just wanted some personal opinions. I use the PC for gaming so i need some fairly good cooling and my original doesn't really cut it. Also, my current case is really poorly made, there is no cable management and there is not much airflow due to the 80mm fans and the lack of ventilation or room. Also, the doors of the case dont fit flush with the rest of the case, they are loose.
Also, if someone has used it, does it have a well or gap in the motherboard tray for aftermarket coolers, e.g. Big Typhoon? I had to do some botch drilling on mine because the nuts used to hold the big typhoon onto the the board are bigger than the golden riser bolts.
Thanks,
Thanks,
