NZXT Beta CUSTOM?
14 Sep 2009
Northumberland
I want this case as a cheap case for my cheap(ish) i7 Build.
Will this case be easily sprayed white? I know i'll have to spray it before I put the stuff in, but will the paint 'stick' easily, and will it look bad with a black optical drive?
not familair with the case, could you post some details.
Done a fair bit of case painting so might be able to help out.
I like the look of this case. Ok it's got a bad review, but up the cooling by adding in a rear fan and perhaps the spec of the front fan (typhoon 1850 is quiet and shifts a lot of air) and you've perhaps got a contender on your hands.
Any way, you didn't ask about that, you asked about painting
there are 3 ways of doing it
1 Strip it down to as many parts as it will come apart into, drill out all the rivits so what you have is a flat pack case. rub it all down then spray in a spray shop or have it powder coated.
2 strip it all down, perhaps unscrew what will unscrew, maybe de rivit, but ultimatly spray it yourself. following rub down will take many coats and many between coat rub downs to get a decent finish.
3 take out what's easy to remove, carefully place a bit of masking tape over what you think might need it, give it a quick going over with sand paper and spray away. then throw the case in the bin cos you've made a complete testicle out of the whole thing, and it's all run and looks like a badgers happy sack.
If you're rich option 1, if you're normal option 2, if you know better option3
I'll probably do option 2, but I may go for the Beta EVO as it has a nice silver finish, and i'll have good intake, and exhaust fans all round :)
Probably get the EVO as i'll end up with the result of option 3 :)
